Finite Element coupling components: definition (structure)
Definition
A stranded coil conductor, 2-terminal solid conductor or N-terminal solid conductor component is defined by:
  • a name (and a comment)
  • a model
  • specific characteristics depending on the model
  • two terminals (stranded coil conductor/2-terminal solid conductor) / N terminals (N-terminal solid conductor)
Name
The name permitting the identification of the component is given by the user when it is created by him.
A comment (optional) can be added to the name.
The name and the comment are displayed by default in the graphic zone close to the symbol.
FE coupling components: description
Characteristic quantities, necessary for the description of the FE coupling components: stranded coil conductor, 2-terminal solid conductor and N-terminal solid conductor, are presented in the table below.
Stranded coil conductor component Description
belonging to a circuit Value of resistance in Ohm
with an imposed current Value of the current in Ampere
Solid conductor component Description
2-terminal solid conductor Information on symmetries and periodicities
N-terminal solid conductor Information on symmetries and periodicities
