Creating the Lua Settings File
Specify the loading and excitations for each port using a Lua settings file.
Open a text editor and create the following settings file:
-- Non-active port configuration nonActivePortsConfiguration = {} nonActivePortsConfiguration.Data = {} -- Empty non-Active port configuration since all ports are active. -- Active port configuration activePortsConfiguration = {} activePortsConfiguration.Load ={} activePortsConfiguration.Load.Data ={} -- Source Port1 source = {} source.Label = "Port1" source.Index = 1 source.Value = pf.Complex(1,0) table.insert(activePortsConfiguration,source) -- Load attached to active port 1 -- Type = 1 (direct connection), -- Type = 2 (complex), -- Type = 3 (one port Touchstone network), -- Type = 4 (two port Touchstone network) load ={} load.Type = 2 load.Value = pf.Complex(10,-30) table.insert(activePortsConfiguration.Load.Data,load) -- Source for Port2 source = {} source.Label = "Port2" source.Index = 2 source.Value = pf.Complex(1,0) table.insert(activePortsConfiguration,source) -- Load attached to active port 2 load ={} load.Type = 2 load.Value = pf.Complex(70,-30) table.insert(activePortsConfiguration.Load.Data,load) -- Source Port3 source = {} source.Label = "Port3" source.Index = 3 source.Value = pf.Complex(1,0) table.insert(activePortsConfiguration,source) -- Load attached to active port 3 load ={} load.Type = 2 load.Value = pf.Complex(105,-30) table.insert(activePortsConfiguration.Load.Data,load) -- Source Port4 source = {} source.Label = "Port4" source.Index = 4 source.Value = pf.Complex(1,0) table.insert(activePortsConfiguration,source) -- Load attached to active port 4 load ={} load.Type = 2 load.Value = pf.Complex(50,0) table.insert(activePortsConfiguration.Load.Data,load) -- Return the configurations in a settings table return {activePortsConfiguration, nonactivePortsConfiguration} - Save the example3_settings.lua file.
