Example 4: Command-Line Interface
The multiport application macro supports calculation from the command-line by calling the application macro via POSTFEKO.
The first example shows how to use a Feko model with the interface. The second example uses a Touchstone file as input.
Note: The settings file can be automatically generated by using
the Save settings to file (*.lua) check box on the
Processing options dialog from the
GUI.
local processingOptions={
["deembedToAntenna"] = "false",
["referenceImpedance"] = "50",
["storeDataSets"] = "true",
["includeSourceReferenceImpedance"] = "false",
["mergeWithExistingStoredData"] = "false",
["calculateScaledRequests"] = "false",
["containsCurrentSource"] = "false",
["exportDataSets"] = "false",
["prefix"] = "",
["storeAdditionalData"] = "false",
["exportScallingCoefficients"] = "true",
["idealSource"] = "true",
["printSummary"] = "true",
["validateModel"] = "false"
local sourceConfiguration={
[1] = {
["Value"] = "1 + 0i",
["Index"] = 1,
["Label"] = "Port_1"
[2] = {
["Value"] = "2 + 0i",
["Index"] = 2,
["Label"] = "Port_2"
["Load"] = {
["Data"] = {
[1] = {
["Label"] = "Port_1",
["Type"] = 1
[2] = {
["Label"] = "Port_2",
["Type"] = 1
local loadConfiguration={
["Data"] = {
[1] = {
["Value"] = "25 + 30i",
["Type"] = "Complex",
["Index"] = 3,
["Label"] = "Port_3"
[2] = {
["Value"] = "75 + 0i",
["Index"] = 4,
["Label"] = "Port_4"
["Type"] = "Individual"
return{sourceConfiguration,loadConfiguration,{},processingOptions}
