This application macro is used for calculating mean effective
gain (MEG) and envelope correlation coefficient (ECC) for a MIMO antenna configuration. The
MEG ratio can also be plotted.
The application macro is used for calculating mean effective gain
(MEG), envelope correlation coefficient (ECC)1. Using the Maths option for the 2D graph, the MEG
Currently, the application macro only supports two channel MIMO: the
two channels are simulated as two separate configurations, each with its far field
request. You can choose to sweep the cross polarization ratio (XPR), sweep the frequency
or both. The propagation environment can also be defined. The default is uniform, with .Figure 1. The Evaluate MIMO performance dialog.
Plots of ECC against XPR or MEG against frequency are plotted depending on the selected
options.
1 M.P. Karaboikis, V.C. Papamichael, G.F.
Tsachtsiris., C.F. Soras and V.T. Makios, Integrating Compact Printed Antennas Onto
Small Diversity/MIMO Terminals, IEEE Transactions on Antennas & Propagation,
Vol. 56, No. 7, July 2008.
