Plot Multiple S-Parameter Traces Macro
Plot multiport S-parameter results.
This POSTFEKO application macro is ideal for plotting multiport S-parameter results, especially for simulations with a large number of ports. The application macro provides the user with the following options:
- Select which S-parameter configuration to analyse.
- Select whether to plot the reflection coefficients and/or transmission coefficients for all ports.
- Set the Y axis to dB.
- Select to create a new graph or to use the most recently created existing graph.
