Tile Windows
An application macro to tile any POSTFEKO views side-by-side.
It is often required to tile views side-by-side in POSTFEKO to visually compare the data in them. This
application macro sets up such a view as follows:
- Start with a POSTFEKO session containing more than one view.
- Run the application macro.
- Select Vertical or Horizontal tile Orientation.
- Select the Windows to tile.
- Select OK.
