Command Line Arguments for Launching the Multiport Post-Processing Macro
The Multiport application macro can be called via the command
line through POSTFEKO. Use the
--configure-script argument to pass configuration information to the
multiport post-processing script.
Use the following command-line parameters to launch the multiport
script:
postfeko [SESSION] --non-interactive --run-script=[SCRIPT] --configure-script="[OPTIONS]"Note: The
--configure-script parameter requires that the input
variables are wrapped in quotes with an empty space separating each
variable.
- SESSION
- A single session (.pfs) may be specified that may or may not exist.
- SCRIPT
- Specify the path to the MultiportPostProcessing.lua file.
- OPTIONS
- mppSettings
- The path to a multiport settings file.
- outputDirectory
- Specify the path for the exported result files.
