Adding a Voltage Source
Add a voltage source to the port of the pin.
On the Source/Load tab, in the
Sources on Ports group, click the
Voltage Source icon.
On the Add Voltage Source dialog, use the default
settings.
Figure 1. The Create Voltage Source dialog.
Click Create to define the voltage source and to
close the dialog.
Note: The Configuration tab was selected automatically when you defined the voltage source. You may also add sources, loads and set the frequency from here.
