Creating the Patch
Create the chamfered1 patch using a polygon.
On the Construct tab, in the Create Surface group, click the
Polygon icon.
Figure 1. The Create Polygon dialog showing the default values. Active fields are outlined in yellow.
Note: Default values are used on geometry creation dialogs to allow a preview in the 3D view. You may change the values as required.Tip: An active field allowing point-entry is indicated by a yellow outline.Point-entry allows a variable or named points to be entered by pressing Ctrl+Shift+left click on a variable or named point in the model tree.
Under Corner 1, add the following coordinates:
- Corner 1:
- U: Patch.patch_size
- V: Patch.patch_size
- N: Substrate.substrate_h
- Corner 1:
In the table, click on the second row to make Corner 2
active. Add the following coordinates:
- Corner 2:
- U: -Patch.patch_size + Patch.chamfer_d
- Corner 2:
Click on the third row to make Corner 3 active. Add the
- Corner 3:
- V: Patch.patch_size - Patch.chamfer_d
- Corner 3:
Click Add row for Corner 4. Add
- Corner 4:
- V: -Patch.patch_size
- Corner 4:
Repeat Step 5
twice to add Corner 5 and Corner 6
using the following coordinates:
- Corner 5:
- U: Patch.patch_size - Patch.chamfer_d
- Corner 6:
- V: -Patch.patch_size + chamfer_d
- Corner 5:
Set the Label to patch.
Figure 2. The Create Polygon dialog.
- Click Create to create the polygon and to close the dialog.
1 An edge created at 45° between two adjoining right-angled
edges.
2 An alternative method is to model the substrate using an infinite planar multilayer substrate. See the Feko Example Guide for an example.
