Setting the Simulation Frequency
Specify the frequency range of interest. For this example continuous frequency sampling is used where Feko automatically determines the frequency sampling for optimal interpolation.
On the Source/Load tab, in the
Settings group, click the
Frequency icon.
- On the Solution Frequency dialog, from the drop-down list, select Continuous (interpolated) range.
- In the Start frequency (Hz) field, enter 1.27e9.
In the End frequency (Hz), enter
1.85e9.
Figure 1. The Solution Frequency dialog.
- Click OK to specify the frequency and to close the dialog.
