CUDA Asserts
The CUDA Solver has an additional option to enable asserts for enhanced error diagnostics.
Enabling this option may cause a minor slowdown in simulation performance. You can
enable this option from the GUI by navigating to , or from the command line using the option "--cuda-asserts
1".
In order to use this effectively, EDEM should be running a
command line simulation or started from the command line using the option
--no-free, so that any additional console output from an assert can
be sent to EDEM Support.
