Set GPU CUDA Simulator Parameters
The EDEM GPU CUDA solver engine will automatically allocate the required memory and resources as the simulation runs.
To review the memory settings in the EDEM GPU CUDA
solver engine, go to .
Note: This might be useful in situations where the
simulation is getting close to the limit of memory available and you can see
the estimated memory usage. In addition, when you select the GPU CUDA solver
engine in EDEM Simulator, the Display GPU Memory
option can be selected which will display the memory usage in the EDEM visualizer.
