GPU CUDA Troubleshooting
The following tips may help resolve any issues while using the EDEM GPU Solver Engine.
CUDA Error Messages
- If EDEM displays any error message related to CUDA, try updating to the latest driver first.
- GPU card manufacturers are regularly updating drivers to fix bugs so make sure you use on the latest driver and check regularly.
- Only after the test has run successfully, the GPU option will be accessible from the Selected Engine dropdown list.
