Asset Remote Access
Remote access to an edge asset is possible by setting up a "tunnel" to the asset. A client application on the edge asset will connect to a cloud side application and enable access to the asset’s kubernetes API server through the use of a kubeconfig authentication file.
Required: installed Edge Application “App - ECP Tunnel”
