Install the Edge Application
  1. Go to the Marketplace and select App - ECP Tunnel. Click on the Add to Space to make it available in your space.
  2. Go to Edge Ops > Edge Apps Management > Edge Applications and create a new configuration for the tunnel app. Leave all options to the default settings.
  3. Go to Edge Ops > Fleet Management > Asset Management and select the asset you want to install this app on. Go to the Applications tab and select the application, then click on Add.
    Figure 3.
    Tip: If you manage the applications on your fleet asset using distributions and rollouts you can add the tunnel application to a new distribution.
