Fleet Management
Fleet Management enables you to create, monitor, and interact with all the Assets in
your ecosystem. This gives you a high level view of what you have deployed and
where. The Fleet Management section is divided into the following sections:
- Asset Management: enables you to add new Assets to your Space for both installation on bare metal or by deploying a pre-installed OS
- Installer Images: allows you to create an installable image for an Asset that can be downloaded and flashed to an USB drive using balenaEtcher
