Skew
Type of skew
The design of the pole can be considered with or without skewing. Hence, two
solutions are proposed:
- None: The pole is not skewed.
- Continuous: The pole is designed with continuous skewing.
Table 1. Pole – Skew - Design area - Skew type available
1 Default setting: skew type is « None ». The pole is not skewed. 2 Button to select a skewed type of pole. Note: The user can add a skew angle on the rotor or on the stator. If a skew is already defined in the rotor when setting a skew on the stator, the rotor skewing will be automatically reset to “None” and vice-versa.
Continuous skew
| 1 | Choose the definition mode of the skew: Three choices are
possible:
Note: whatever the definition mode is,
the resulting shift angle must be an element of [-180.0, 180.0]
(deg). |
| 2 | Visualization of the chosen skew angle on the machine radial view. |
| 3 | Visualization of the equivalent rotor axial skew angle on the machine-developed view. |
| 4 | Equivalent axial rotor pole angle (read only). |
| 5 | Equivalent stator slot pitch (read only). |
| 6 | Equivalent rotor slot pitch (read only). |
