Introduction
Documents can be attached to User’s libraries. This allows quick access to the additional information to describe these libraries.
Note: Documents can be attached only to user’s libraries.
Note: Documents can be linked to libraries as well as to parts. See chapter Management of parts.
How to create an attachment?
Table 1. How to attach a document to a library in Part Library?
1 Button (+) to add an attached document.
2 A dedicated dialog box allows adding a new attached document.
All kind of documents can be attached (like Word, Excel, PDF or text files, pictures etc.).
2a Give the attached document name.
2b Select the folder in which the document to be attached is stored.
2c It is possible to write a reminder dealing with the attached document.
Management of attachments
Table 2. Management of attachments
1 Selection of an attached document.
Once selected, a tooltip (1’) reminds the name and the description of the selected document.
2 Button (+) to add an attachment.
3 Button (-) to remove one or several attachments.
4 Button for removing all the attached files.
