The WinProp propagation models allow the computation of
multiple floors in a building. Creating such a multi-floor database is very easy when all
floors have the same layout. In such a case just one floor must be modeled and saved to a
file. To add floors, select File > Import > WinProp Binary Database from the menu and select the file that contains the already modeled
floor.
Figure 1. The Move Objects dialog.
WallMan asks for the values by which the additional floor
should be shifted. Enter the height of one floor in the Z field and click
OK. For additional floors, the Z value must be increased for each
floor.Figure 2. Indoor database with four floors.
