Create an Empty Indoor Database
A new indoor database can be created by selecting WallMan opens a dialog where the user can choose from different creation modes. For an empty database Indoor Database and Draw manually must be chosen.
from the menu.![](../../../../../images/winprop/user_guide/wallman_tuman/wallman_usage/dialog_select_type_new_database.png)
The next dialog sets some default values for the new database.
![](../../../../../images/winprop/user_guide/wallman_tuman/wallman_usage/dialog_default_values_new_objects.png)
- Geometrical Parameters for Orthogonal Drawing Mode
- Only relevant if the orthogonal drawing tool should be used. Object relative to current plane creates new orthogonal objects with a fixed height and a position that is relative to the current projection plane. Upper and lower coordinate defined individually creates new orthogonal objects with a fixed height and at an absolute position.
- Material Properties
- The default materials for new objects in the database.
