Conversion of Indoor Databases
Convert an indoor database (.idb file) to an outdoor database (.odb file).
If an urban database is desired, for example, if the database consists mainly of buildings, then you can use .odb file, WinProp's format for urban databases. Then, the buildings will be approximated by extruded polygons and be suited for an urban simulation, which can be faster.
to save the geometry to a
