To change the unit of a result, click Edit > Convert Unit. Figure 1. The Units dialog.
The following options are available on the Unit dialog:
Path loss (dB)
Received power (dBm)
Field strength, log. (dB(uV/m))
Field strength, linear (dBW/m2))
Power density (mW/ m2)
The unit for distance on a 2D value plot can be changed to nautical miles by clicking on
the plot and from the right-click context menu, click
Settings. On the Parameter dialog
(Scaling tab), select the Nautical
Miles check box.Figure 2. The Parameter dialog.
