Mathematical Operations
In ProMan it is possible to add, subtract, or multiply the values contained in a result file to / from / with another constant value or even another result file. Mathematical operations on result files can be found on the Edit menu.
A combination of two result files is also possible to get a result file which contains the maximum, the minimum or the mean value of the two selected result files. Combine result file by clicking
