Calculate urban propagation in the city of Munich using the COST 231 - extended Walfisch-Ikegami model.
Model Type
The geometry is described by topography (elevation) and by urban buildings, see Figure 1. Each building is
modeled as an extruded polygon. The database was preprocessed; therefore result
prediction height and result resolution are fixed. Figure 1. The topographic and urban buildings overview of the model.
Figure 2. The power results for Site 2 Ant 2.
Sites and Antennas
The model has three sites with three different antennas placed at different locations
and heights of 20 m, 28 m, and 30 m. The frequency of propagation is 1.8 GHz, and
the transmitter power of an antenna is 43 dBm.
Tip: Click Project > Edit Project Parameter and click the Sites tab to view the
antenna settings.
Results
Propagation results show at every location the power received by a hypothetical
isotropic receiver from each transmitting antenna. See Figure 2 for the results of
Site 2 Antenna 2, at a receiver height of 1.5 m.
