Indoor with Multi-Wall
Compute path and transmission losses in a multi-floor building.
This example model uses the multi-wall model (COST 231) for indoor environments, which is illustrated using two different building environments. The multi-wall model computes the path loss based on the basic path-loss exponent as well as transmission losses. The path loss exponent is set to 2 for free space but can be set higher when people and furniture are present. The transmission losses for the walls and floors are calculated along straight paths between the transmitter and receiver.
