Single Height
Compute path and transmission losses on a single prediction plane.
Model Type
The propagation project is for an indoor scenario for a large multi-floor building. The simulation is done for a single prediction plane.
Sites and Antennas
There are six transmitter sites at different locations in the office building for better propagation. All the transmitter sites are placed at different locations but the same height of 0.9 m. The omnidirectional transmitters are using the same carrier frequency of 1.8 GHz and transmit equal power.
Computational Method
The computational method used is the multi-wall model (COST 231). The multi-wall model considers the basic path losses plus transmission losses for the walls and floors given a straight path between the transmitter and receiver.
Results
Propagation results show, at every location, the power received from each transmitting antenna individually. The results are provided for a single prediction plane at a height of 0.9 m.
