Rural, DPM
Calculate rural propagation using the dominant path model (DPM).
Motivation for the DPM
The dominant path model (DPM) is a proprietary 3D ray-tracing model that focuses on the dominant path (the path along which most power is expected to travel). Therefore it is faster than ray tracing models. It is also more accurate far from the transmitter since it can include more diffractions.
Examples
This example contains four projects that use the DPM in the following scenarios:
  1. Rural/suburban placing the site at a height above sea level
  2. Rural/suburban placing the site at a height above ground
  3. Rural/suburban, coastal area
  4. Rural propagation for the island of Curacao
