SS-V: 2090 Triangular Wing - Fixed Vibration
Test No. VM10 Perform a normal mode dynamic analysis of a fixed right triangular plate.
Definition
The plate is 6 in long and 0.034 in thick.
The units are IPS.
The material properties are:
    - Properties
 - Value
 - Modulus of Elasticity
 - 6.5e6 lb/in2
 - Poisson's Ratio
 - 0.3541
 - Weight density
 - 0.06414 lb/in3
 - Mass density
 - 1.66128e-4 lb-s2/in4
Results
The following table summarizes the
          modes.
| Reference | SimSolid | % Difference | |
| Mode 1 [Hz] | 55.900 | 55.707 | -0.35% |
| Mode 2 [Hz] | 210.900 | 209.940 | -0.46% |
| Mode 3 [Hz] | 293.500 | 290.660 | -0.97% |
1  I.S. Tuba and W.B. Wright, ASME Pressure
        Vessel and Piping 1972 Computer Programs Verification, ASME publication, I-24, Problem
        2
