SS-V: 2130 1D Damped Oscillator: Translation or Rotation
Test No. VM14Determine the frequency and damping rate of a 1D damped oscillator.
Definition
The material properties are:Figure 1. Translation motion
                Figure 2. Rotational motion
        - Steel or rigid body, m = 0.00784998 [kg], k = 1[ N/m], c = 0.1 [N·s/m], Izz = 1.30833e-07 [kg·m2] , krot = 1[N·m/rad], crot = 6.0e-04 [N·m·s/rad]
Modeling and Results
The spring and damper is modeled with a bushing. To restrict
                motion to one dimension, sliding conditions are applied on two sides of the
                cube-shaped body for translational motion or on one side for rotational motion.
                Frequency and rate of damping are compared to the values from the analytical
                solution. The below results are for bushing.
| Parameters | SimSolid, Steel, Translation | Analytical solution |
| Frequency, Hz | 1.4830 | 1.48295 |
| Damping rate, 1/s | 6.3692 | 6.3694 |
| Parameters | SimSolid, Steel, Rotation | Analytical solution1 |
| Frequency, Hz | 2.4582e+02 | 2.45815e+02 |
| Damping rate, 1/s | 2.2930e+03 | 2.2930e+03 |
1  Kausel E.,
                “Advanced Structural Dynamics”, Cambridge University Press, 2017,
            p.86.
