The Prepare Window
Prepare allows you to transform columns, using Prep Data operations, to prepare your data for subsequent analysis.
Prepare Window panels
Panel
The standard  Data Prep Studio Toolbar
Select a tool to move to the Start Page, Preview Window, Transform Pane, Combine Stage, Analyze Drop-down, or Export Window.
2
Table Selector
Lists all the tables you have selected and loaded from the Preview Window.
You can toggle viewing and hiding this panel by selecting the Hide/View Tables icon:
You can click on the drop-down arrow located to the right of each table to display an action menu.
3
Data Preview
Displays sample rows from the currently-selected table. The Data Preview panel allows you to visually confirm the data in your tables.
Icons on the header readily tell you a column's data type:
 Date/Time
 Number
 Text
You can easily change the data type of a column by clicking the data type icon and selecting a different data type from the options that display.
The heights of column headers and data rows can be modified by drag-resizing them in the Prepare Window. Row height changes are saved in the workspace and do not affect the values indicated in the Application Default Settings. Thus, when the workspace is reopened, the same row heights set by drag-resizing are preserved.
4
Prep Data Operations
A drop-down list that displays when you right-click on a column or click on a column header. Select the operation from the drop-down list.
The operations that display are specific to the column's data type.
5
Navigation Controls
These controls will help you search for table details, go to a different row in the table, show nulls, and increase the size of the table text, among others.
6
Workspace Information
Click this icon to launch a popup that provides complete details on your workspace.
7
Save Workspace
Use this icon to automatically save your workspace.
8
You can save workspaces and tables to the Library. Clicking this icon displays the Library dialog.
9
Settings
Click to set Current Workspace or Application Default settings.
10
Change History Panel
Click to hide or unhide the Change History Panel and work with Change History.
11
Action Bar
The buttons displayed in the action bar vary according to the active table displayed in the Prepare window. You can use these buttons to perform quick operations on your table, such as edit file paths or add metadata columns.
12
Application Menu
Click on this button to display a menu showing additional Data Prep Studio options. You can:
Preparing data from Report Design
Data tables extracted from PDF files may be prepared in the same way that tables obtained from other data sources, such as databases, text reports, and the like, are prepped. However, changes such as column name revisions, splits, and other operations, are NOT reflected in the Report Design preview when you return to the Report Design window via the Edit in Report Design action.
Should you wish to review your data prep operations once more, exit Report Design and return to the Prepare window. If you edit a report and remove a column that was used in data prep operations, this column, as well as all other operations done to it, will no longer be visible when you return to the Prepare window.
Related Links
© 2025 Altair Engineering Inc. All Rights Reserved.
