The Current Workspace Settings
Current Workspace settings allow you to define current workspace-level settings for Data Prep Studio.
Import
GENERAL
GENERAL
Setting
Default source row limit
Specifies a row limit to enable the partial data loading of excessively large files and improve the application's performance.
To do so, use the dropdown provided and select Limit: from the options that display. In the field that appears to the right of this selection, specify a row limit to apply when opening tables.
Notes:
  • The number of rows displayed does not affect the number of rows obtained when a table is exported. You could, for example, set a limit of 10,000 rows to view when opening a table with 1,000,000 rows. When ready, you may opt to export only 10,000 rows or all 1,000,000 rows as necessary.
  • The application imposes a 2,000-record limit when opening SalesForce reports. To get a full view of the data when opening SalesForce reports with over 2,000 rows, export the data to a CSV file in SalesForce and then use the Text plugin to import the data.
Automatically sync columns with source data on load or refresh data for supported data sources
Instructs Data Prep Studio to sync columns with the data source when opening a workspace or refresh data for supported data sources (delimited text, Excel).
While in this mode, your Change History items may reflect errors if the column they were applied to is renamed or deleted from the source file. The supported data types for this mode are delimited text and Excel.
Apply to existing tables
Applies the specified settings to all tables in the current workspace.
EXCEL
Setting
Default sample size when detecting Excel column types
Specifies how Data Prep Studio should determine the data type of a column in an Excel data source.
Take the following example:
Column A
Row 1              1234
Row 2              4569
Row 3              4568
Row 4              4562
Row 5              4562A
If the default sample size is set to 4, Data Prep Studio will scan up to Row 4 and the column datatype will be Numeric. When the table is displayed, Row 5 will be NULL. If the default sample size is set to 5, Data Prep Studio will scan up to Row 5 and the column datatype will be Text. All values from Rows 1-5 are displayed.
Select a sample size that ensures Data Prep Studio can make a correct assessment of the data type. At the same time, be mindful that if you select a very large sample size, you sacrifice speed in loading data.
Import all columns as text to avoid potential loss of data during type conversion
Converts all columns imported from the data source as text regardless of their original type.
Note:
This option is only available via the Monarch Excel Table import connector.
WORKSHEET DESIGN
Setting
Utilize unformatted values from Excel for numeric and date columns
Instructs the application to use unformatted values from Excel cells for various operations, including cell/column type detection, "Is Number" and "Is Date" value rule behaviors, and the output table values for numeric and date columns, when opening a data source in Excel Worksheet Design.
Recursively evaluate formulas
Instructs the application to calculate dependent cells in a worksheet if this worksheet's cells depend on the cells of other worksheets.
Note:
This setting may have an important impact on the application's performance, particularly if numerous cells must be calculated.
DELIMITED TEXT
Setting
Rows to scan for columns
Specifies a number of rows that must be scanned by Data Prep Studio to determine what data type to assign to a certain column.
Note:
Setting this number to a very high value may negatively impact the application's load performance depending on the number of rows and columns in your input source.
Formatting
Specifies the encoding type to apply when loading the table into your workspace.
The encoding types enabled for delimited-text files include:
  • Code Page
  • UTF-8
  • UTF-16LE
  • UTF-16BE
When Code Page is selected as the encoding type, the Code Page dropdown is activated, and you can select the code page to apply to your delimited text file.
REPORTS
Setting
FORMATTING
Encoding
Specifies the default report file format.
The following encoding types are supported by Data Prep Studio:
  • ASCII: Select to make Data Prep Studio interpret report files as ASCII text and perform the conversion to ANSI. This is the default setting because most report files are created as ASCII text files.
  • ANSI: Select to make Data Prep Studio read report files as ANSI text and perform no conversion. While most report files are created as ASCII text files, report files generated from Windows applications may be created as ANSI text files. The difference lies with characters 128 - 255 in the character set: in these positions, the ANSI character set includes international characters not present in the ASCII character set.
  • UTF-8  (8-bit Unicode Transformation Format): Select to make Data Prep Studio interpret report files as UTF-8 files. UTF-8 is a variable-length character encoding for Unicode, which is able to represent any character in the Unicode standard, yet it is backwards compatible with ASCII. If a valid BOM (Byte order mark) is detected within the input file, then Data Prep Studio will automatically select the UTF-8 type when opening the file.
  • UTF-16 LE (16-bit Unicode Transformation format, Little Endian): Select to make Data Prep Studio interpret report files as UTF-16 LE files. UTF-16 LE is the Unicode Transformation Format that serializes a Unicode value as a sequence of two bytes, in little-endian format. If a valid BOM (Byte order mark) is detected within the input file, then Data Prep Studio will automatically select the UTF-16 LE type when opening the file.
  • UTF-16 BE (16-bit Unicode Transformation format, Big Endian): Select to make Data Prep Studio interpret report files as UTF-16 BE files. UTF-16 BE is the Unicode Transformation Format that serializes a Unicode value as a sequence of two bytes, in big-endian format. If a valid BOM (Byte order mark) is detected within the input file, then Data Prep Studio will automatically select the UTF-16 BE type when opening the file.
  • EBCDIC (Extended Binary Coded Decimal Interchange Code): Select to make Data Prep Studio interpret report files as EBCDIC files. EBCDIC is an eight-bit character encoding system used mainly on IBM mainframe and IBM mid-range computer operating systems.
These options may also be accessed in open files by right-clicking on the report in Report view.
Code page
Selects the appropriate code page to use with the chosen input file encoding format.
This option is only applicable to the ASCII (14 code pages available), ANSI (10 code pages available), and EBCDIC (16 code pages available) encoding systems.
File Type
Specifies the file type to use with the EBCDIC encoding option.
This option is enabled only when EBCDIC is selected as the encoding type. The available options are:
  • Auto - Selecting this option instructs Data Prep Studio to automatically determine the record/line delimiter.
  • Line Feed (LF) - This file type includes files where the end of record is an ASCII line feed character.
  • Carriage Return (CR) -This file type includes files where the end of record is an ASCII carriage return character.
  • EBCDIC New Line (NL) - This file type includes files where the end of record is an EBCDIC new line character.
  • EBCDIC Line Feed (LF) - This file type includes files where the end of record is an EBCDIC line feed character.
  • Fixed-length record - This file type includes files where each line (or record) consists of a fixed number of characters/bytes.
  • Variable-length record - This file type includes files consisting of variable length lines (or records). Each record is preceded by a 4 byte record descriptor that specifies the record length.
  • Variable length block - This file type includes files similar to variable-length records but also includes a block descriptor.
  • Undefined-length record - This file type includes files with no defined record length or block.
  • Custom byte as EOL - This file type includes files where the end of line is marked by a custom number of characters/bytes
Ignore print control characters
Instructs Data Prep Studio to ignore all print control characters below ASCII 32 except for:
  • Form Feed (ASCII 12)
  • Line Feed (ASCII 10)
  • Carriage Return (ASCII 13)
  • TAB (ASCII 09)
  • Null (ASCII 0) which is converted to a space (ASCII 32).
Ignore additional non-printing and control characters
Instructs the application to ignore Unicode characters in the report.
A number of Unicode characters are known to cause misalignment issues with Report Design's character position-based data capture. These characters include U+008D (reverse line feed), U0080 (padding character), U+200B (zero-width space), and U+FEFF (zero-width no-break space), for example.
Hide n leading characters on each line
Specifies the number of leading characters to strip from each line of a report. Typical values are 0, 1, and 2. The value can be in the range 0-99.
When you download print files from a network, a mini-computer, or a mainframe, one or more extra characters may appear at the beginning of each line. The exact number and type of characters depends on the operating system. These introductory characters are typically used for form feed, carriage return, or line feed printer commands. They are usually not needed in a PC file and may affect the way the file is displayed by Data Prep Studio.
A few communications programs are smart enough to either discard unnecessary characters or translate useful characters into the corresponding PC character codes. However, a form feed command is typically the only useful character you may get, and most communications programs are unable to translate it.
For example, if you download from an IBM 3090 mainframe computer using an IRMA communications card, each line in the report will be preceded by two non-productive characters. Using this setting, you can strip those characters from the data by entering 2 in the Hide n leading characters box.
PAGE BREAK
Ignore the form feed character
Instructs Data Prep Studio to ignore all form feed (page break) characters in a report.
Use this setting to turn off the hard-coded page breaks in a report file and replace them with page breaks based upon a Page Header trap or based upon the Force Page Break After n Lines setting (see below).
Page break on hidden leading text: n
Instructs the application to hide control characters and force a page break when a specified character is encountered.
For some mainframe and mid-range system generated reports, especially from AS/400 systems, a page break could be indicated by a leading control character in the report file. This setting will allows you to hide this character and force a page break instead.
Note:
This option is not accessible unless you specify a Hide n Leading Characters on Each Line setting.
Force page break after n lines
Adds a page break to a file at regular intervals.
When a value for this setting is specified, Data Prep Studio scans the report for existing page breaks and inserts a virtual page break whenever a real page break has not been encountered before the number of lines specified.
FIELDS
Trim leading and trailing spaces from Character and Memo fields
Instructs the application to remove all leading and trailing spaces from character and memo fields.
TRAP CHARACTERS
Trap characters
Specifies whether to use Monarch Complete's standard trap characters or  alternate ones.
The Alternate trap characters have been chosen to be compatible with different languages, so that characters that are commonly used in a language are not chosen as wildcard trap characters. For example, in the standard trap character set, the Alpha Trap uses a character which is common in Portuguese, the Numeric Trap uses a character which is common in Spanish, the Blank trap uses a character which is common in German, and the non-blank trap uses a character that is common in Scandinavian languages.
  • English (Standard):  Select to use Monarch Classic's standard trap characters. (This is the default setting.)
  • Latin: Select to use Latin alternate trap characters.
  • Low ASCII: Select to use Low ASCII alternate trap characters.
Note: The characters used in the Alternate trap set are all low ANSI, i.e., lower than character code 128, so they will be consistent across all code pages.
Non Regex traps are case-sensitive When enabled, automatically sets all non-regex traps to be case-sensitive.
XML
Setting
Encoding
  • Code Page
  • UTF-8
  • UTF-16LE
  • UTF-16BE
Use simplified column names When selected, instructs the application to open the XML table using simplified column names as column headers.
Allow empty tags as columns
When selected, this setting instructs the application to allow the import of XML elements with no values as columns.
This setting applies for both self-closing (e.g., <Name/>) and conventionally tagged (e.g., <Name></Name>) elements.
Apply to current Workspace
Applies the specified settings to the relevant tables in the current workspace.
Note, however, that visiting Edit Table Info for each related table is necessary to reestablish the schema and see some changes (i.e., use simplified column names, allow empty tags as columns) take effect.
JSON
Setting
Formatting
  • Code Page
  • UTF-8
  • UTF-16LE
  • UTF-16BE
Use simplified column names When selected, instructs the application to open the JSON table using simplified column names as column headers.
Note, however, that visiting Edit Table Info for each related table is necessary to reestablish the schema and see some changes (i.e., use simplified column names) take effect.
Export
Setting
EXCEL
Apply formatting to XLS and XLSX files (Y/N)
Directs Data Prep Studio to apply table formatting when exporting to XLS and XLSX files.
Enable advanced Excel features (Y/N)
Instructs the application to enable advanced Excel features during export.
DELIMITED TEXT
Delimiter
Specifies the character to use for separating field values when exporting to a delimited text file (comma, tab, semicolon, space, pipe).
Text Qualifier
Specifies a text qualifier (i.e., where text values begin and end) for CSV files.
Select the desired text qualifier from the drop-down (double quote, single quote, none).
Quote column names (Y/N)
Instructs the application to enclose column names with quotes.
DELIMITED TEXT/XML
Legacy compatibility mode - Ignore format customizations during export (Y/N)
Instructs the application to ignore column format customizations when exporting numeric and date columns in favor of Monarch Classic-style formatting.
When using Monarch Classic formatting, numeric values are exported using the current system's localized decimal separator, and date values are exported according to the Date Format setting.
Legacy Compatibility Settings: Date Format
Specifies the date format when exporting data to a delimited text file.
This setting can be configured only when the Delimited Text/XML > Legacy compatibility mode - Ignore format customizations during export setting is enabled.
The valid date format options are:
  • yyyy-mm-dd
  • yyyymmdd
  • current Windows Regional Settings
DELIMITED TEXT/FIXED TEXT/TEXT REPORTS
Append DOS end-of-file character (x1A) (Y/N)
Specifies whether to append a DOS end-of-file character (x1A) to the end of the file.
This option is provided to enable compatibility with systems that expect the data in this format. This end-of-file character is often known as Control-z.
Encoding
Specifies the encoding type to apply when exporting data to a delimited text file.
The possible encoding types are:
  • Code Page
  • UTF-8
  • UTF-16LE
  • UTF-16BE
Include Column Headers (Y/N)
Instructs the application to include column headers when exporting to the delimited text/fixed text format.
FIXED TEXT
Insert a page break after n lines (Y/N)
Instructs the application to inserts a page break after n lines, which can be specified using the selector provided.
Repeat field names on each page
Instructs the application to add field names at the beginning of each new page. This setting is enabled only when the Include Column Headers option is selected.
Pad each field with n extra space
Instructs the application to separate exported fields with n extra spaces when exporting to a fixed text file.
With this option cleared, field values might "bump up" against each other producing, for example, "123.45CD" rather than "123.45 CD".
Pad generically formatted numeric fields with zeros, suppress the decimal point, and use trailing negation
Instructs the application to export generically formatted numeric fields using a standardized format that pads each value with leading zeros, removes the decimal point and places the negation sign at the end of the field value.
This format represents the number "-123.45" as "00012345-". Note that padding is applied only to numeric columns with the formats F, F<n>, G, or G<n>.
Default decimal precision when not supplied by column format
Specifies a fallback value to use when a decimal precision cannot be determined from the format string.
Note:
The "n" in the format G<n> denotes significant digits, NOT decimal precision. Thus, any G format will use this fallback value.
TEXT REPORTS
Insert page breaks in reports
Instructs the application to insert page breaks at predefined points in multi-page reports.
  • Before first page and between pages
  • Never
  • Between pages only
PDF
Text Encoding
Specifies the text encoding type for PDF exports.
The possible values are:
  • User current system locale
  • Western
  • Japanese
  • Simplified Chinese
  • Traditional Chinese
MISCELLANEOUS
Use summary measure labels as column names during database exports (Y/N)
Instructs Data Prep Studio to use summary measure labels as column names.
When cleared, the underlying field name, instead of the label, is used to name measure columns.
Include field names as the first row when using Ctrl+C to copy the clipboard
Instructs the application to use column headers as the first row of any table created using the CTRL + C command.
Apply to existing exports
Applies the specified settings to all exports defined in the current workspace.
Conversion
Setting
From text to numeric
Decimal Separator - Specifies the character to use as a decimal separator when converting text into a numeric value. You can select:
  • Period
  • Comma
From text to date
Date Format - Specifies the format of dates used when converting text into a date value. You can select:
  • M/D/Y
  • D/M/Y
  • Y/M/D
First Year of Century - Specifies the first year of the century (100-year range) to use when converting two-digit years into four-digit years. The default value is 50 (i.e., 1950-2049).
Extraction Pattern - Specifies the pattern applied to a text string when converted into a date/time value. You can select:
  • Date
  • Date, then Time
  • Time
  • Time, then Date
Display
Setting
Default Locale
Sets the global language to be used by the application.
When specified, this locale is used to display table cell values on screen. It can also be used to match join keys of differing types.
Default Numeric Format
Specifies the default format to apply to numeric columns until fomatting changes are applied.
Clicking the Edit  icon displays the Default Numeric Format dialog, from which the default numeric format can be selected.
Default Date Format
Specifies the default format of date/time columns.
When specified, Data Prep Studio applies this format until other formatting changes are applied
Default Fonts
Specifies the default font and font size to use in tables, reports, and summaries.
Dropdowns to select a default font and font size are provided.
DATA VALUES
Suppress zero values
Suppresses zero values when viewing data.
Suppressed zeros are not printed, but are exported as zero values when the Table or Summary data are exported or copied to any format except text. For text export and copy operations, the suppressed zeros are exported as space characters to retain column integrity.
Note that Data Prep Studio implements zero suppression based upon the value that is returned to each cell after any rounding has been done on the value. For example, if you set the precision of a cell containing the value 0.004 to two decimal places, the application will round the value to 0.00. Since this value equates to zero, it will be suppressed if zero suppression is turned on. This is not the case in other applications, such as MS-Excel, where the underlying value 0.004 is retained and evaluated against zero. In Excel, the cell would be displayed as 0.00 and would not be suppressed, since its underlying value (0.004) is not equal to zero.
Display nulls as text
Applies the column type Text to all columns with null values.
Display null values as
Determines how null values should appear on screen in the Prepare window.
You may enter a text string to use when representing null values.
In Data Prep Studio, as in most other database applications, a null value represents an unknown value or a value that cannot be calculated. Data Prep Studio returns null values under a variety of situations:
  • When a calculated field expression causes division by zero.
  • When the Minimum or Maximum calculation is used in a summary if no records match the key field values for a cell (e.g., there are no records of media type "CD" for the customer "Bluegrass Records"). In this case, no data is available to the cell.
  • When the Standard Deviation or Variance calculation is used in a summary if only a single record matches the key field values for a cell. In this case, there is insufficient information available to perform the calculation.
  • When the denominator in a Ratio measure calculation evaluates to zero causing the Ratio calculation to result in division by zero.
The application exhibits the following behavior when evaluating expressions and calculations that reference one or more null values:
Evaluation
When a null is used in an evaluation, the expression always evaluates to False. This is the case even when a null is evaluated against another null. The reason is that null is treated as an unknown value (when two unknown values are evaluated against each other, it cannot be said that they are equal).
Data Prep Studio's expression engine also does not support the constant NULL, so evaluations like the following one cannot be made: If(Amount=NULL, true result, false result)
However, an indirect method of evaluation against null will work in Data Prep Studio. For example, let's say that you want to create a filter in the Table window that removes all records where the Amount field value is null. Let's say that you also know that the Amount field values are never likely to be larger than 1,000,000.00 (one million) or smaller than –1,000,000.00 (negative one million). You could use either of the following filter expressions to remove records whose values are null:
Amount>-1000000
or
Amount<1000000
Either expression will evaluate to True for all records that contain a valid value in the Amount field, and will evaluate to False for all records that contain a null in the Amount field (since an evaluation against null returns False).
Calculation
When a null is referenced in a calculated field expression, the result of the expression is null. For example, the expression Amount*0.2 returns the Amount field value divided by 5 for all records where Amount contains a number. For records where Amount contains null, the expression returns null.
When one or more null values are included in a measure aggregation, the null values are ignored. This can produce the desired result or an unexpected result, depending upon your point of view. For example, the Average(Amount) calculation returns the average Amount by dividing the sum of the Amount values by the Count (the number of records from which the function drew Amount values). Records for which the Amount value is null are not included in the calculation. A different result is returned by the Ratio(Amount:Count) calculation, as this calculation tallies the Amount values and the Count values in two steps. First, the sum of the Amount values is calculated, then, in isolation, the Count for all records matching the same key field values is determined. Thus, in a Ratio calculation, the Count represents all of the records, including those whose Amount field contains null.
Highlight null cells
Instructs the application to highlight null (as opposed to, for example, blank) cells in the table/summary
Show whitespace characters
Instructs the application to show whitespace characters in the table/summary.
DEFAULT ROW HEIGHT
Lines in column title row
Specifies the default height for column titles in the Table and Summary windows.
You may set the height from 1-12 lines. Column titles that are too long to fit on a single line will wrap to fit.
Lines in data rows
Specifies the default height for data rows in the Table and Summary windows.
You may set the height from 1-12 lines. Data values that are too long to fit on a single line will wrap to fit.
This setting is ignored if Automatically increase row heights to fit multi-line data is enabled.
AUTOMATIC ROW SIZING
Automatically increase row heights to fit multi-line data (Y/N)
Instructs the application to increase row heights automatically to accommodate multi-line data.
DEFAULT COLUMN DISPLAY WIDTH AND ALIGNMENT
Display Width
Specifies the default display width (measured in number of characters) for rows
Text Alignment
Specifies the default alignment for text, numeric, and date/time fields.
  • Left
  • Center
  • Right
Numeric Alignment
Time Alignment
Apply to existing tables, reports, and summaries
Applies the specified settings to all tables, reports, and summaries in the current workspace.
Note:
Date columns from report sources will not reflect changes to the Default Date format. To change the format these columns, you must create a format change or modify the field in Report Design.
Time Intervals
FISCAL YEAR
Setting
Month-based (12 calendar months starting on a designated month)
Specifies that the fiscal year consists of 12 calendar months.
First month of the fiscal year
Selects the month of which the first day begins the new fiscal year.
Week 1 starts on January 1
Specifies that the first week of the fiscal year begins on January 1.
Each week starts on a specified weekday
Defines the start of a fiscal week and the week number of a partial week, if any, at the start of the year.
Week-based (52 or 53 whole weeks)
Specifies that the fiscal year consists of 52 or 53 whole weeks. You can specify the first day of each fiscal week, a reference month and day, and a rule for year start or end.
Select to divide the year into four 13-week quarters, then pick one of the following:
  • 4-4-5 - Select to specify that each quarter is divided into a period with a pattern of 4 weeks, 4 weeks, 5 weeks.
  • 4-5-4 - Select to specify that each quarter is divided into a period with a pattern of 4 weeks, 5 weeks, 4 weeks.
  • 5-4-4 - Select to specify that each quarter is divided into a period with a pattern of 5 weeks, 4 weeks, 4 weeks.
The year is divided into four 13-week quarters
Divides the year into four 13-week quarters and allows you to choose a week distribution pattern and quarter and period in which to place the 53rd week if necessary.
The year is divided into thirteen 4-week periods.
Divides the year into thirteen 4-week periods  and allows you to choose a period in which to place the 53rd week if necessary.
CALENDAR WEEK
Setting
Week 1 starts on January 1.
Specifies that the first full week of the year starts on the first day of the week on or after January 1.
Specifies that the week begins on a specific weekday and allows you to set a week number for a partial week.
FORMATTING
Setting
Interval
Lists the names of the time intervals available.
Formatting Mask
Displays the formatting mask applied to the adjacent interval. To edit the formatting mask, double-click on the desired time interval, or select an interval and press the Edit Formatting Mask button .
Sample Value
Shows the effect of the formatting masks on today’s date. To change the date that the sample value is based on, adjust the sample date calendar control accordingly. This control is located on the right-hand side of the dialog immediately below the table containing the time intervals.
Displays a description of each time interval.
Page Setup
The following default page setup settings apply to tables, summaries, and reports unless otherwise indicated.
PREFERENCES
Setting
MARGINS
Top
Specifies a value representing the top margin.
The default value is .5" or 1 cm, depending on the Windows Control Panel Measurement setting.
Bottom
Specifies a value representing the bottom margin.
Left
Specifies a value representing the left margin.
The default value is .5" or 1 cm, depending upon the Windows Control Panel Measurement setting.
Right
Specifies a value representing the right margin.
OPTIONS
Show Grid lines
Instructs the application to print the grid lines between rows and columns, as displayed on screen.
These settings are applicable only to tables and summaries.
Show Column Titles
Instructs the application to print column titles at the top of each page.
Note that when applied to Excel exports, the export will also contain row numbers. PDF exports will require the additional "Show Row Numbers" to replicate this behavior.
Show Row Numbers
Instructs the application to print row numbers as displayed on screen.
These settings are applicable only to tables and summaries for PDF exports.
Repeat Suppressed Values on New Page
Instructs the application to ignore the Suppress Duplicate Values setting for all key fields when printing the first line of each page of a summary.
This setting is only applicable to summaries for PDF exports. When selected, all key values for the first line on a page are printed, even if they are suppressed in the summary display.
EXPORT PAGINATION
Paper Size
Specifies the desired paper size.
Orientation
Specifies the desired paper orientation.
  • Portrait
  • Landscape
Apply to existing exports/summaries
Applies the specified settings to all exports/summaries in the current workspace.
HEADER/FOOTER LAYOUT
Settings for header and footer layouts are only applicable to tables and summaries.
Setting
Page Header display box
Specifies text to print in headers.
A page header may include up to 3 lines, each with text left-aligned, centered, or right-aligned text. Enter text into the boxes provided. You can insert special characters and/or variables by clicking on the left arrow button and selecting the item from the list of variables:
  • Page number
  • Total pages
  • Date
  • Time
  • Filter Name
  • Sort Name
  • Summary Name
  • Input Name
  • Workspace Name
Use custom font
Specifies font options.
Security
Setting
Select credentials that should be cleared from saved items
Specifies what types of credentials should be cleared from saved items, such as workspaces:
  • Password (always deleted when clearing is employed)
  • Account ID
  • User name
  • Service account email
  • Access token
  • Refresh token
  • Secret key
Define connection string parameters that should be cleared from saved items
Identifies strings that should be considered a sensitive connection parameter when saving details for OLE DB data sources and connectors for which the field Other Connection Options is provided in the connector dialog.
When Data Prep Studio saves a connection detail and encounters the specified sensitive connection parameter (e.g., "password"), it "scrubs" (i.e., deletes) the selected string according to the save behavior defined above.
Note:
Microsoft Jet/ACE drivers use a specific password parameter for connection strings that must be added to the default clearing settings to maintain parity with password clearing in other sources.
This parameter is: "Jet OLEDB:Database Password"
This parameter will be added to the default parameters in its normalized, lower case form and will appear as: "jet oledb:database password."
Runtime Parameters
Allows you to define and set values for runtime parameters that can be used by all tables in the current workspace.
Refer to Working with Runtime Parameters for details on defining and using runtime parameters.
Metadata Columns
You can specify the types of metadata to import into your workspace when you open data sources based on delimited text, Microsoft Excel, HTML, JSON, PDF/text report, and XML files.
File Type
Metadata Columns
Delimited text
File created
File last modified
Source filename
Excel
File created
File last modified
Source filename
Sheet number
Sheet name
HTML
File created
File last modified
Source filename
JSON
File created
File last modified
Source filename
PDF/Text report
Report column
Report file created
Report file last modified
Report filename
Report file number
Report line
Report page count
Report page
PDF Producer
XML
File created
File last modified
Source filename
When the Apply to <File Type> tables in current Workspace box is enabled, all metadata columns selected for the specified <file type> tables will be imported into the current workspace.
User-Defined Functions
Allows you to add user-defined functions, import them from existing models or workspaces, and manage (i.e., edit, copy, and delete) user-defined functions.
© 2025 Altair Engineering Inc. All Rights Reserved.
