Find
Find entities in the model that contain the search string you enter. The search results are not filtered.
- Press F2 to open the Model Browser.
                Click
 to open the Find toolbar.
 - Optional:
                To control your search, click
, and then click one or more of the following
                    options:
                - Match Case
 - Whole Names Only
 - Use Wildcards
 - In the text field, type a search string.
Find Options
| Option | Description |
                            Navigate to the next or previous entity that contains the search string. |
                            Find every entity that contains the search string. |
                            Access additional options to control the search:
