Mass Calculation
Mass calculation allows masses to be calculated and displayed in the Model Browser.
To improve overall performance, when a CAD file is imported the mass sizes are not calculated and are shown as ** in the Model Browser.
- Press F2 to open the Model Browser.
 - To display mass in the Model Browser, right-click the Object column.
                Turn on Mass to show the column.
                    Tip: Because the mass calculations are continually updated as you make changes to the model, larger models may exhibit a slowdown in performance when this option is enabled. To hide the column, right-click the column header and turn off Mass. - Click the Calculate button to display the mass of a part. A nonzero mass indicates a solid object.
Note: You can override a selected part's mass in the Property Editor. This
                will affect measure weight calculations and motion calculations, but not structural
                analysis calculations.
