Split
Use the Split tools to split a cage with a loop or split a single PolyNURBS cage face.
Split Cage with Loop
Draw an edge loop around a cage, subdividing the PolyNURBS object to gain more control when editing the cage.
On the PolyNURBS ribbon, select the Split Cage with Loop
tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. -
Click the edge of an existing cage to create a loop perpendicular to that edge.
Mouse over an existing edge to preview the loop.
The loop is created at the point where you clicked.
- Optional:
To reposition the loop:
- Drag the loop.
- Hold down Ctrl while clicking the loop, and then use the graphic manipulators.
Split Faces
Split a single PolyNURBS cage face.
On the PolyNURBS ribbon, select the Split Faces tool on
the Split icon.
Click a point on one edge where you want to split the face.
Tip: Hold down the Alt key to temporarily disable snaps.
- Click a second point on one of the face's other edges to split the face.
Keyboard Shortcuts & Mouse Controls
To | Do this | Notes |
Temporarily disable snaps (PolyNURBS tool) | Alt | |
Change the transparency of the underlying shape (STL or optimization result) | Alt+middle mouse scroll | |
Add to or remove from the selection Select a loop an enter editing mode |
Ctrl | |
Delete a selected split or loop | Delete | |
Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
