Shell & Offset
Use the PolyNURBS Shell & Offset tool to offset the vertices of PolyNURBS part bodies and optionally shell the bodies by connecting copied offsets.
Shell a PolyNURBS Part
Offset duplicates of bodies after removing their selected faces and connect the duplicates back to their original bodies with thin walls.
                On the PolyNURBS ribbon, select the Shell & Offset
                        tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select a PolyNURBS part to edit.
 - In the guide bar, select Shell.
                Select a cage face to remove, then enter the Wall
                        Thickness. Faces added to the selection will also be removed.
                    The thickness value is applied to the remaining faces.
                A preview of the shelled PolyNURBS part is displayed.
 - Optional:
                To apply the shell in the opposite direction, select
                        Reverse
                Click Apply
 to confirm the preview and keep the shell.
Offset PolyNURBS Bodies
Move body vertices inside or away from their current positions.
                        tool.
 - In the guide bar, select Offset.
                Select a body to offset, then enter the Offset Distance.
                    You can add bodies from the part to the selection. The offset distance is
                    applied to selected bodies.
 - Optional:
                To apply the offset in the opposite direction, select
                        Reverse
                Click Apply
