Wrap
Use the Wrap tool to quickly wrap a PolyNURBS solid around an optimized shape. You can create multiple PolyNURBS cages, and bridge the face of one cage to another. You can also wrap a hole or negative space.
                On the PolyNURBS ribbon, select the Wrap tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. -
                Click the existing shape to define the first section.
                As you mouse over the shape, a preview of the first section is displayed. Red lines indicate the true section through the geometry, while the black lines indicate the actual face that will be created.
                Click a second time to define the next section.
                As you mouse over the shape, a preview of the next section is displayed. Moving the mouse along the section preview orients the cage face.
 - Continue clicking along the existing shape to create additional sections.
 - Click in the modeling window to complete the cage.
Tip:
        - You can start or end a block from any existing cage face. You can also end a block on a planar face.
 - Rotate an existing cage face using the graphic manipulators that appear when you mouse over an edge.
Wrap Holes
Use the Wrap Holes tool to wrap a hole or negative space in a polyNURBS or optimized shape.
                On the PolyNURBS ribbon, select the Wrap Holes
                        tool.
                Click on a hole or negative space to start a section.
Keyboard Shortcuts & Mouse Controls
| To | Do this | Notes |
                                 Change the section preview so that it is aligned to the underlying shape rather than parallel to the face  |
                            Alt | |
| Change the transparency of the underlying shape (STL or optimization result) | Alt+middle mouse scroll | |
| Create an edge loop when selecting an edge | Shift | |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
