Motors and actuators have a profile option on the
microdialog that allows you to change how the shaft moves as time elapses (or another
independent variable changes).Functions is an option in
the micro dialog of the Motion Analyst forces and motions entities that lets you access
predefined functions from inside a Profile Editor.
The following profile functions are available:
Step
Step Dwell Step
Single Wave
Oscillating
Swept Sine
Impulse
Ramp
Multi-Signal
The Profile Editor icon is located on the micro dialog for Force
and Motion. The icon to the right of the Profile Editor icon is for display only and
shows the current function being used.
Figure 1. Profile Editor Icon in Microdialog
Click on the icon to open the Profile Editor. The available functions can be
accessed from the Function drop-down list.
Figure 2. Motors microdialog: Profile functions
Figure 3. Force or Motion Microdialog and Profile Editor
Note: You can change the parameters of a profile function using
the Property Editor.
Profile Types: Examples
Learn about various profile types with example waveforms and usage notes for motion
profile configuration.
Step
Step Dwell Step
Single Wave
Note: Use the time spanspan parameter to adjust the duration of the waveform.
Oscillating
