Flexible Body Cannot be Assigned a User-Defined Mass
Condition
Mass and inertia properties cannot be overridden (customized) on flexible bodies.
Remedy
Define a user material with a density that will align the mass and/or inertia properties with the desired properties, then assign the user material to the part(s).
