Motor or Actuator Joint is Locked
Condition
The joint where the motor or actuator has been applied is set to Locked, so the motor or actuator cannot move.
This error message has two versions:
- Motor Joint is Locked
- Actuator Joint is Locked
Remedy
Click the Fix button to unlock the joint. This
will set the joint state to Active.
