Coupler Requires Joints to be Rigid and Active
Condition
This error message has two versions:
- Coupler Requires Joints to be Rigid and Active
- Coupler Requires Supports to be Rigid
Tip: To avoid this error, click
in the guide bar, and then select Force coupled joints to be
rigid before creating the coupler.
rigid before creating the coupler.Cause 1: Coupler Requires Joints to be Active and Non-Flexible
Click Fix to make the coupler's joints active
and rigid.
Cause 2: Coupler Requires Supports to be Rigid or Virtual
Click Fix to make the support behavior rigid for
all supports in your model.
Cause 3: Coupler Requires Implicit Joints to be Rigid or Virtual
Click Fix to make the implicit joint behavior
rigid for all implicit joints in your model.
