/PROP/TYPE5 (RIVET) (Obsolete)
Block Format Keyword Describes the rivet property set.
| /PROP/TYPE5/prop_ID/unit_ID or /PROP/RIVET/prop_ID/unit_ID | |||||||||
| prop_title | |||||||||
| Fnmax | Ftmax | Lmax | flag | Iform | |||||
Definition
| prop_ID | Property
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| prop_title | Property
| Fnmax | Maximum normal
force (Real) |
| Ftmax | Maximum tangential
force (Real) |
| Lmax | Maximum length If L > Lmax rivet is broken (Real) |
| flag | Rotations transmission flag
(Integer) |
| Iform | Formulation flag
(Integer) |
