/MAT/LAW13 (RIGID) (Obsolete)
Block Format Keyword This material law is used to model part(s) as rigid bodies.
/MAT/LAW13/mat_ID/unit_ID or /MAT/RIGID/mat_ID/unit_ID
mat_title
ρ i
E v
Definition
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ i Initial density
(Real)
[ kg m 3 ]
E Young's modulus
Used for computing stiffness in interface
(Real)
[ Pa ]
v Poisson's ratio
Used for computing stiffness in interface.
(Real)
Example (Rigid)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW13/1/1
rigid material
#              RHO_I
                 .78
#                  E                  NU
              210000                  .3
#ENDDATA
/END
  1. /MAT/RIGID is not compatible with kinematic condition or with Advanced Mass Scaling (/AMS), but it is compatible with /BCS.
  2. /MAT/RIGID is not compatible with /PLOAD, /CLOAD, /GRAV, /IMPDISP, /IMPVEL, /IMPACC, /IMPTEMP, /INIVEL and /INITEMP. If loading is used, it is recommended to use /RBODY, instead of /MAT/RIGID.
