/MAT/LAW51 (Iform = 3) (Obsolete)
Block Format Keyword This formulation handles Outlet conditions for Multi-Material ALE domain (formulation: Iform = 0, 1, 10 or 11).
Initial state must be provided for each sub-material present in adjacent ALE domain.
| /MAT/LAW51/mat_ID | |||||||||
| mat_title | |||||||||
| Blank Format | |||||||||
| Iform | |||||||||
#Material1 Parameters
#Material2 Parameters
#Material3 Parameters
Definition
| mat_ID | Material
| mat_title | Material
| Iform | Formulation
flag (Integer) |
| Initial volumetric
fraction 1 (Real) |
| Initial
density (Real) |
| Initial energy per unit
volume (Real) |
| Initial
pressure (Real) |
- Initial volumetric fractions
enable the sharing of elementary volume within the three different materials.
For each material, must be defined between 0 and 1.
Sum of initial volumetric fractions must be equal to 1.
- It is recommended to build boundary layer elements normal to the direction of the modeling flow.
- Outlet element state is computed using initial values and affected quantities from adjacent element.
