Ityp = 0
Block Format Keyword This law enables to model a gas inlet condition by providing data from stagnation point. Gas is supposed to be a perfect gas.
law11_ityp0
/MAT/LAW11/mat_ID/unit_ID or /MAT/BOUND/mat_ID/unit_ID
mat_title
ρ i stagnation ρ 0 stagnation
Ityp Psh FscaleT
Ityp = 0 - Gas Inlet (from stagnation point data)
node_IDV C1 Cd
fct _ ID ρ
fct_IDp P 0 stagnation
Blank Format
Blank Format
fct_IDT fct_IDQ
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i stagnation Initial stagnation density. 3
(Real)
[ kg m 3 ]
ρ 0 stagnation Reference density used in E.O.S (equation of state).
Default ρ 0 stagnation = ρ i stagnation (Real)
[ kg m 3 ]
Ityp Boundary condition type. 1
= 0
Gas inlet (from stagnation point data)
= 1
Liquid inlet (from stagnation point data)
= 2
General inlet/outlet
= 3
Non-reflecting boundary
(Integer)
Psh Pressure shift. 2
(Real)
[ Pa ]
FscaleT Time scale factor. 3
(Real)
[ s ]
node_IDV Node identifier for velocity computation. 4
= 0
v in = min ⁡ nod e   ε   face     v → n o d e ⋅ n →
> 0
v in = ‖ v node _ ID ‖
(Integer)
γ Perfect gas constant.
(Real)
Cd Discharge coefficient. 5
(Real)
fct_ID ρ Function f ρ ( t ) identifier for stagnation density. 3
= 0
ρ stagnation ( t ) = ρ i stagnation
> 0
ρ stagnation ( t ) = ρ i stagnation ⋅ f ρ ( t )
(Integer)
fct_IDp Function f P ( t ) identifier for stagnation pressure. 3
= 0
P stagnation ( t ) = P 0 stagnation
> 0
P stagnation ( t ) = P 0 stagnation ⋅ f P ( t )
(Integer)
P 0 stagnation Initial stagnation pressure. 3
(Real)
[ Pa ]
fct_IDT Function f T ( t ) identifier for inlet temperature. 3 6
= 0
T = T adjacent
= n
T = T 0 ⋅ f T ( t )
(Integer)
fct_IDQ Function f Q ( t ) identifier for inlet heat flux. 3 6
= 0
No imposed flux
= n
Q = f Q ( t )
(Integer)
  1. Provided gas state from stagnation point ( ρ stagnation ,   P stagnation ) is used to compute inlet gas state.
    A set of equations including Total Enthalpy formulation, Adiabatic Law and Equation of State allows for the complete definition of the inlet state:
    ρ in = ρ stagnation ⋅ [ 1 − γ − 1 2 γ ⋅ ρ stagnation P stagnation ⋅ ( 1 + C d ) ⋅ v in 2 ] 1 γ − 1 P in = P stagnation ( ρ in ρ stagnation ) γ ( ρ e ) in = P in γ − 1
  2. The Psh parameter enables shifting the output pressure which also becomes P-Psh. If using Psh=P(t=0), the output pressure will be Δ P MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaadc faaaa@37E5@ , with an initial value of 0.0.
  3. If no function is defined, then related quantity ( P stagnation ,   ρ stagnation ,   T ,   or   Q ) remains constant and set to its initial value. However, all input quantities ( P stagnation ,   ρ stagnation ,   T ,   and   Q ) can be defined as time dependent function using provided function identifiers. Abscissa functions can also be scaled using FscaleT parameter which leads to use f (Fscalet * t) instead of f(t).
  4. Inlet velocity v in is used in Bernoulli theory.
  5. Discharge coefficient accounts for entry loss and depends on shape orifice.
    mat_bound_sharpedge
  6. With thermal modeling, all thermal data ( T 0 ,   ρ 0 C P , ...) can be defined with /HEAT/MAT.
  7. It is not possible to use this boundary material law with multi-material ALE laws 37 (/MAT/LAW37 (BIPHAS)) and 51 (/MAT/LAW51 (MULTIMAT)).
