Ityp = 2
Block Format Keyword This law enables to model a material inlet/outlet by directly imposing its state.
/MAT/LAW11/mat_ID/unit_ID or /MAT/BOUND/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
Ityp | Psh | FscaleT |
Blank Format | |||||||||
fct_IDp | P0 | ||||||||
fct_IDE | E0 | ||||||||
fct_IDT | fct_IDQ |
Definition
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density 3 (Real) |
Reference density used in E.O.S
(equation of state) Default (Real) |
Ityp | Boundary condition type 1
(Integer) |
Psh | Pressure shift 2 (Real) |
Fscalev | Time scale
factor
3 (Real) |
fct_ID | Function
identifier for boundary density
3
(Integer) |
fct_IDp | Function
identifier for boundary pressure
3
(Integer) |
Initial pressure 3 (Real) |
fct_IDE | Function
3
(Integer) |
Initial energy 3
6 (Real) |
fct_IDT | Function
identifier for boundary temperature
3
4
(Integer) |
fct_IDQ | Function
identifier for boundary heat flux
3
4
(Integer) |
- Provided state is directly imposed to inlet
boundary elements. This leads to the following inlet state:
(1) With this formulation, you may impose velocity on boundary nodes to be consistent with physical inlet velocity (/IMPVEL). /MAT/LAW11 - ITYP=0 and 1, are based on material state from stagnation point, where you do not need to imposed an inlet velocity.
- The Psh parameter enables shifting the output pressure which also becomes P-Psh. If using Psh=P(t=0), the output pressure will be , with an initial value of 0.0.
- If no function is defined, then related quantity remains constant and set to its initial value. However, all input quantities can be defined as time dependent function using provided function identifiers. Abscissa functions can also be scaled using FscaleT parameter which leads to use f (Fscalet * t) instead of f(t).
- With thermal modeling, all thermal data ( , ...) can be defined with /HEAT/MAT.
- It is not possible to use this boundary material law with multi-material ALE laws 37 (/MAT/LAW37 (BIPHAS)) and 51 (/MAT/LAW51 (MULTIMAT)).
- Specific volume energy
E is defined as
, where
is the internal energy. It can be output using
/TH/BRIC.
Specific mass energy e is defined as . This leads to . Specific mass energy e can be output using /ANIM/ELEM/ENER. This may be a relative energy depending on user modeling.
