/ALE/GRID/DONEA
Block Format Keyword Velocity of a given grid node depends on velocity and displacements of neighboring grid nodes.
/ALE/GRID/DONEA | |||||||||
Fscalex | Fscaley | Fscalez | |||||||
Vmin |
Definition
DONEA
coefficient Default = 0.0 (Real) |
Grid velocity limitation
factor Default = 100 (Real) |
Fscalex | X grid velocity scale
factor Default = 1.0 (Real) |
Fscaley | Y grid velocity scale
Fscalez | Z grid velocity scale
Vmin | Elements with a volume
less than Vmin will
be deleted Default = -1030 (Real) |
- This option is available for 2D and 3D analysis.
- Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
