/ALE/GRID/DISP
Block Format Keyword The displacement of a grid node depends on the displacements of the neighboring grid nodes.
| /ALE/GRID/DISP | |||||||||
| Umax | |||||||||
| Vmin | |||||||||
Definition
| Umax | Maximum absolute grid
velocity. Default = -1030 (Real) |
| Vmin | Elements with a volume
less than Vmin will
be deleted. Default = -1030 (Real) |
- Grid nodes displacement depends
on the displacement of the neighboring nodes based on the following
equation:
- Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
