2025
Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
View new features for Radioss 2025.
Current Radioss format uses the 12x extension format.
The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
Keywords used to set the default value.
Block Format Keyword Describes the part group on which the advanced mass scaling is applied.
Block Format Keyword Defines the type of analysis and sets analysis flags.
Block Format Keyword Defines the eigen modes and static modes computation for flexible bodies.
Block Format Keyword This card defines values of parameters in the Starter file that will be used throughout the Radioss model.
Block Format Keyword This option can be used to study the robustness of a design by generating different failure values for every shell or solid element using the failure model. The random noise scale factors can have either a normal (Gaussian) distribution or random distribution.
Block Format Keyword This option can be used to study the robustness of a design by generating different thickness values for every shell element in the specified part group. The random noise scale factors can have either a normal (Gaussian) distribution or random distribution.
Block Format Keyword This option can be used with Deshpande-Fleck foam law (/MAT/LAW115) to create a density distribution of the foam over all solid elements of a part. The random noise scale factors can have either a normal (Gaussian) distribution or random distribution.
Block Format Keyword Describes the nodal random noise to check stability of model by introducing random noise on nodal coordinates.
Block Format Keyword Defines a local unit system for the keywords listed below.
Block Format Keyword In this group, keywords are used to set Rayleigh mass and stiffness damping coefficients, which apply to a set of nodes used to stabilize the results.
Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
