/ALE/GRID/SPRING
Block Format Keyword Grid nodes are connected with nonlinear springs (those springs have no effect on the material, only on the movement of the grid).
/ALE/GRID/SPRING
Δ t 0 γ η ν MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@
Vmin
Definition
Δ t 0 Typical time step
(Real)
[ s ]
γ Nonlinearity factor
Default = 0.0 (Real)
η Damping coefficient
Default = 0.5 (Real)
ν MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@ Shear factor
Default = 1.0 (Real)
Vmin Element with a volume less than Vmin will be declared
Default = -1030 (Real)
[ m 3 ]
  1. This option is available for 3D analysis only.
  2. Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
  3. Effective time step Δ t 0 * MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bWaa0baaSqaaiaaicdaaeaacaGGQaaaaaaa@3B5C@ is computed using damping parameter:(1)
    Δ t 0 * = Δ t 0 η+ 1+ η 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaqGuoGaam iDamaaDaaaleaacaaIWaaabaGaaiOkaaaakiabg2da9maalaaabaGa aeiLdiaadshadaWgaaWcbaGaaGimaaqabaaakeaacqGHsislcqaH3o aAcqGHRaWkdaGcaaqaaiaaigdacqGHRaWkcqaH3oaAdaahaaWcbeqa aiaaikdaaaaabeaaaaaaaa@46F0@
