/ALE/GRID/LAPLACIAN
Block Format Keyword ALE grid smoothing using the Laplacian smoothing method for 2D and 3D elements.
| /ALE/GRID/LAPLACIAN | |||||||||
| Niter | |||||||||
Definition
| Scale factor for grid update. 1 Default = 1.0 (Real) |
| Niter | Number of iterations. Default = 1 (Integer) |
- The grid is
smoothed using the formula:
Where, is a user parameter with a default value of 1.00.
- Several iterations
may be defined, but usually 1 iteration per cycle is enough
(Niter=1).
